6-Contributor
Aug 29, 2022 12:31 PM UTC
INFOTABLE max rows 500
I see that the maximum rows handled by INFOTABLE is mentioned as 500. Can we store more than 500 rows Infotable in a variable? like if we call a service say GetImplementingThings() inside another service which returns more than 500 rows,  can TWx still can iterate through that INFOTABLE variable and carry out rest of the process say inspect  or update a property? What is the best way to handle
nmutterAnswer
Sep 1, 2022 9:03 PM UTC
There is no limit. The only issue is that the service you referenced does not allow to set maxItems parameter. When the parameter exists you need to set it to a high number (you do not expect to reach any time soon).
For your useCase you need to call QueryImplementingThings instead of GetImplementingThings (which is useless as it will only return 500 entries) - and specify maxItems. See also https://www.ptc.com/en/support/article/CS290970
For maxItems we started to use constant "Number.MAX_SAFE_INTEGER" to not have to worry we set it to low.
Aug 29, 2022 1:05 PM UTC
  • Can we store more than 500 rows Infotable in a variable? YES
  • can TWx still can iterate through that INFOTABLE variable? BASED ON THE LOGIC IT MAY TAKE SO MUCH TIME
Sep 1, 2022 6:21 AM UTC
Refer to the best practice to use InfoTable at article https://www.ptc.com/en/support/article/cs266583
Sep 1, 2022 11:25 AM UTC
My colleague provided already the correct answers above, but I wanted to add that I doubt that we specify anywhere in our documentation or product that infotables can handle only 500 rows. Could you let us know where you saw that statement? If indeed this is the case, it must be corrected. Most probably composer says it displays maximum 500 rows only, but the variable itself does not have such limit.
nmutter17-PeridotAnswer
Sep 5, 2022 12:01 PM UTC
Hi SK_9989757,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please designate the appropriate post as the Accepted Solution for the benefit of other members who may have the same question.
If not, please post your current status in the public thread so that we can continue to support.
Iuliana
