Infotable Source on Widget Development
Hi everybody,
I have been stuck on this for a while. I had developed several widgets before but I had never needed an infotable as output/source. I have found an small example as answer on another topic of this forum, but I can´t seem to make it work. I tried to use the Grid widget that Thingworx has an example, but I am still stuck.
On the .ide file, I have the infotable defined as this:
'EditedTable': {
'isBindingSource': true,
'baseType': 'INFOTABLE',
'description': 'Infotable where all the modifications are getting saved'
And on the .runtime file I have it like this:
var outputTable = TW.InfoTableUtilities.CloneInfoTable({ "dataShape" : { "fieldDefinitions" : infoTableDataShape}, "rows" : item_Data_array });
this.updateProperty('EditedTable',outputTable);
I think I am using the correct syntax and that the format of the item_data_array is the right one since I compared it to the infotable that I use as input on the widget (the datashape is directly read from the input one). I have even tried to break the code on the developer mode on Chrome just before setting it, and set this outputTable as the response that I have on the service that send the input infotable.
If it is not so clear, I could add some screenshots.
JNanin
jamesm1Answer
Hey @karnoia,
I have done this before in a widget and just took a look at the differences, and the only thing I see is that I am using setProperty instead of updateProperty;
First, I have a global variable valled clonedRows that I set when the bound data is refreshed:
 this.updateProperty = function (updatePropertyInfo) {
 // TargetProperty tells you which of your bound properties changed
 if (updatePropertyInfo.TargetProperty === 'Data') {
 dataRows = updatePropertyInfo.ActualDataRows;
 clonedRows = TW.InfoTableUtilities.CloneInfoTable({ "dataShape" : { "fieldDefinitions" : updatePropertyInfo.DataShape}, "rows" : updatePropertyInfo.ActualDataRows });
 if(thisWidget.getProperty("IsEditable") === true) {
 thisWidget.setProperty('EditedTable', clonedRows);
 updateWidget();
 } else if (updatePropertyInfo.TargetProperty === 'ErrorIndex') {
 errorRow = parseInt(updatePropertyInfo.SinglePropertyValue);
 console.log('errorRow = ' + errorRow);
 thisWidget.updateErrorRow();
Then, whenever I update the widget I change the corresponding row in the clonedRows table and set the EditedTable property again:
 // called whenever we need to redraw the widget
 var updateWidget = function() {
 $('#' + thisWidget.jqElementId + '> .ruleviz-segment').remove();
 if (dataRows && dataRows.length > 0) {
 for (var i = 0; i < dataRows.length; ++i) {
 var row = dataRows[i];
 var html = '';
 if (isEditable && row.Type === 'PROPERTY' ) {
 html = '<input class="ruleviz-segment ruleviz-segment-' + row.Type + '" placeholder="' + row.RulePart +'">'
 + '</input>';
 } else {
 html = '<div class="ruleviz-segment ruleviz-segment-' + row.Type + '">'
 + row.RulePart
 + '</div>';
 thisWidget.jqElement.append(html);
 // If the table is editable then only to selection/on click on the inputs and not the divs.
 if (isEditable) {
 $('#' + thisWidget.jqElementId + '> input.ruleviz-segment').bind('click', segmentOnClick);
 thisWidget.jqElement.find('input').bind('change', function() {
 var index = $(this).index() - 1;
 clonedRows.rows[index].RulePart = $(this).val();
 thisWidget.setProperty('EditedTable',clonedRows);
 } else {
 $('#' + thisWidget.jqElementId + '> .ruleviz-segment').bind('click', segmentOnClick);
Let me know if this helps.
Thanks!
Support
Hi @karnoia.
Have you checked the logs for error messages?  That may shed some light on the cause of the problem.
--Sharon
karnoia1-VisitorAuthor
Hi @slangley,
Thanks for the reply. I had checked them and the console of the navigator too, but I am not getting any errors related to that. If I link the Infotable Source to a service to read the data, I get that the infotable is undefined, like it wasn't properly defined. But since I have even tried with the structure of the input Infotable, I don't know what else to do.
JNanin
Support
Hi @karnoia.
It sounds like you are creating your own widget.  If so, we would need the widget to review and try to recreate the issue.  Are you able to share that?
--Sharon
