Input capable list using Repeater widget
  • September 6, 2012
  • 14 replies
  • 5373 views
My understanding is that the Repeater is one widget that can be used to display an input capable list structure.  I have a service that returns a data shape based infotable.  How do I build an input capable list structure using this infotable?
Hi Vish, I just have the button in the Parent mashup, what happens on the Add/Update is that it will process the whole Infotable, so each row within the Repeater is Added or Updated if necessary.
I haven't tried it this way but you can try using the Mashup Paramenter Changed event. Or the Selected Row changed from the parent.
vishp1-VisitorAuthor
Pai, it would help if I can look at your example.   I am getting an error when trying to import your example - "Data Table Thing: CGCEMTasksTable has an invalid data shape".  Let me know.  Thank you
Thank you for your help.  I got the repeater widget working for a long input capable list.  If the list size exceeds the repeater widget height, the scroll bar shows up.   If I scroll down and scroll back up, I am loosing any content that was keyed in before scrolling down.  How would I persist the content ?
That behavior doesn't sound right - let me look into it and get back to you.
Hi Tony,
I am also facing the same problem like  Viswesh Palasur.
"How would I persist the content ? If the list size exceeds the repeater widget height, the scroll bar shows up.   If I scroll down and scroll back up, I am loosing any content that was keyed in before scrolling down."
is there any update on this post?  Thank you.
