Install error with Thingworx Analytics 8.0 on linux
- 4 replies
- 4059 views
- Translate All
Hey All,
Just wanted to get some advice on and error i am getting trying to install Analytics 8.0 on linux.
Background
1. Running Cenots 7 64 bit
2. local install of Postgresql 9.5
I have ran the install script using the a local DB with the following setting
port :8097
Host: <ip address>
username : postgres (default superuser)
password: default postgres
Install works fine the and then URL versioninfo works BUT some of the Database tables have not been install , and i would like to understand why and how to fix .
Attached a with the output from a "docker logs analytics" command
Cheers
Paul B
