Installation error of "ThingWorx Trial Edition Installer" on windows 7
can not install the package "ThingWorx Trial Edition Installer". At the end of the installation the installer reports an error:
Executing D:\twx\ThingWorxTrialEdition\win-installer/ThingWorxIndustrialConnectivity.exe /qn /e ACCEPT_EULA=YES
Script exit code: 1603
Script output:
Script stderr:
Program ended with an error exit code
Error running D:\twx\ThingWorxTrialEdition\win-installer/ThingWorxIndustrialConnectivity.exe /qn /e ACCEPT_EULA=YES: Program ended with an error exit code
There has been an error.
Failed to execute installation action for Thingworx Industrial Connectivity"
Anybody has an idea ?
Best Regards
Andras Horti
Hi
Could you please upload all the .log files that exist inside <ThingWorx Trial Edition> folder (by default C:\Program Files (x86)/ThinWorxTrialEdition
Thank you
Kind rgeards
Christophe
ahorti1-VisitorAuthor
Hi Christophe,
tanks a lot, following are the logs.
Best Regards
Andras
Hi Andras
Thank you for the logs.
Those logs shows that port 8080 is in used on the machine which then create error in ThingWorx Trial Edition 8.1.
You will find some information about this at https://www.ptc.com/en/support/article?n=CS278599
Kind regards
Chrisotphe
