Installed ThingWorx6.5 and get below neo4j db error in Tomcat's log.
16-Mar-2017 19:01:47.593 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 45408 ms
rg.neo4j.kernel.impl.transaction.XaDataSourceManager@53da5e37' was successfully initialized, but failed to start. Please see attached cause exception.
at org.neo4j.kernel.lifecycle.LifeSupport$LifecycleInstance.start(LifeSupport.java:513)
at org.neo4j.kernel.lifecycle.LifeSupport.start(LifeSupport.java:115)
at org.neo4j.kernel.InternalAbstractGraphDatabase.run(InternalAbstractGraphDatabase.java:346)
Caused by: org.neo4j.kernel.impl.storemigration.StoreUpgrader$UpgradingStoreVersionNotFoundException: 'neostore.nodestore.db' does not contain a store version, please ensure that the original database was shut down in a clean state.
at org.neo4j.kernel.impl.storemigration.UpgradableDatabase.checkUpgradeable(UpgradableDatabase.java:78)
at org.neo4j.kernel.impl.storemigration.StoreMigrator.needsMigration(StoreMigrator.java:135)
Never mind. It is resolved.
I had installed previous version and removing ThingworxStorage and ThingworxBackupStorage folder did help.
ptc-42136161-VisitorAuthorAnswer
Hi Pashupati Pandey​,
Could you please mark your answer as correct so that other members know that this issue is resolved.
