Oct 4, 2018 12:38 PM UTC
Integrating barcode scanning functionality in mashup
How to implement barcode scanning in thingworx? The requirement is, scanning the labels on equipment and use the information further in a database query as an input.
Sujata.
Oct 5, 2018 7:52 PM UTC
Hello, Sujata.
Possibly the QR Code Extension (available from the PTC Marketplace) could be of help. This is specific to QR Codes, and not necessarily general barcode scanning.
-- Craig A.
Oct 8, 2018 9:54 AM UTC
Hello Craig,
Thanks for the reply. I will check if we can use the QR codes in place of barcodes. In parallel, it would be great if i  get the desired behavior, by doing any customization to achieve barcode sacnning or  any kind of listener that can be implemented to make it possible?
Sujata.
Oct 23, 2018 6:31 PM UTC
Hi, Sujata.
I have not been able to find a more general barcode scanning extension in the Marketplace. I would think you should be able to create a custom extension using the ThingWorx SDK, depending on your exact use case.
In the meanwhile, have you had any luck with the QR Code implementation?
Thank you,
-- Craig A.
22-Sapphire I
Oct 23, 2018 8:11 PM UTC
If it is possible to use a separate scanner vs. using a camera. you can get one that basically functions as a 'text input'
You select a box on a mashup then scan the code with the scanner and it will input the translated text in the box.
Support
Oct 31, 2018 8:09 PM UTC
Hi @Sujata_Shinde.
If one of the previous suggestions answered your question, please mark it as the Accepted Solution for the benefit of others who may have the same question.
--Sharon
