Integration of highchart.js, d3.js or chart.js into ThingWorx
Hi all, I am trying to modify the XY chart widget but I cannot modify the TW.ChartLibrary package as I do not have access to it. I have created a new XY chart extension based on the existing one (see attached zip file) and I want to know whether it is possible for me to integrate the APIs of highchart.js, d3.js or chart.js into my JavaScript code so that I can modify the extension correctly without touching the TW.ChartLibrary package. If integration is possible, how can I do so?
kahmeng96Answer
Hi @slangley,
My requirements are as follows: I want to create a custom XY chart widget (similar to the existing XY chart widget) in ThingWorx and I want the x-axis to be on the top of the chart so that the intersection of the x-axis with the y-axis is in the top left corner instead of the bottom left corner. The x-axis values should increase from left to right and the y-axis values should increase from top to bottom.
However, I have already used the d3.js library to help me draw the chart as I did not want to modify the TW.ChartLibrary. Nonetheless, it will be great if you could suggest any other ways to meet my requirements.
Support
Hi @kahmeng96.
Can you provide some specifics around what you are developing?  We have some new beta widgets that may provide the functionality you're needing.  We began introducing those in ThingWorx 8.4.
--Sharon
kahmeng961-VisitorAuthor
Hi @slangley,
What I am currently trying to develop is described in the link below. Appreciate if anyone could help!
https://community.ptc.com/t5/ThingWorx-Developers/Changing-x-axis-and-y-axis-of-XY-chart-widget/m-p/625193#M38844
Support
Hi @kahmeng96.
We're not clear on your requirement.  What is missing from the solution you already found?
--Sharon
