Interpolate data in stream
Is there a easy/fast way to interpolate all data in a stream?
I would like, given a startDate and endDate and a step, a stream with timestamps every step, and values the interpolation of the original data.
My stream:
timestapvalue
2017-10-27 15:13:25.123557
2017-10-27 17:19:11.024678
2017-10-27 20:02:34.987558
2017-10-27 23:45:13.356547
2017-10-28 02:12:56.223447
2017-10-28 03:27:16.133469
I would like this result:
timestapvalue
2017-10-27 16:00576,53
2017-10-27 18:00626,85
2017-10-27 20:00679.08
2017-10-27 22:00614.50
2017-10-28 00:00664.63
2017-10-28 02:00655.65
where values come from the interpolation formula
v* = v_0 +[(v_1 - v_0 ) / (t_1 - t_0)]*(t* - t_0)
I tried the service "Interpolate" but doesn't seem to work.
Thank you
    fmanniti1-VisitorAuthor
    This is how I used Interpolate function
    (start and end are given as input)
    var propertyColumn = "Strain_Measure_Current";
    var queryOnStream = {"filters":{"type":"LIKE","fieldName":propertyColumn,"
    var streamFiltered = me.QueryStreamEntriesWithData({oldestFirst: true, query: queryOnStream});
    var params = {
        mode: 'ROWCOUNT',
        timeColumn: 'timestamp',
        t: streamFiltered,
        stats: 'SMOOTH',
        endDate: end,
        columns: propertyColumn,
        count: 50,
        startDate: start
    result = Resources["InfoTableFunctions"].Interpolate(params);
    I get this error
    java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.Double - 17
