Interpolate function not working as expected
Hi All,
I have an infotable that has missing values (interpolate_1),
I use the following code (interpolate_params) to try and fill the gaps by the last element.
	var params = {
		mode: "INTERVAL" /* STRING */ ,
		timeColumn: "timestamp" /* STRING */ ,
		t: loggedValues /* INFOTABLE */ ,
		ignoreMissingData: false /* BOOLEAN */ ,
		stats: "LAST" /* STRING */ ,
		endDate: endDate /* DATETIME */ ,
		columns: "p1_plasma__cooling_water__conductivity__actual;p1_plasma__cooling_water__conductivity__limit_high" /* STRING */ ,
		count: 1000 /* NUMBER */ ,
		startDate: startDate /* DATETIME */
	// result: INFOTABLE
	var interpolatedLogged = Resources["InfoTableFunctions"].Interpolate(params);
For some reason, the gaps are not filled, and the timestamp is not stretched correctly.
Please let me know what am I doing wrong ?
18-Opal
March 30, 2020
Hello @ronyT,
I did some quick test and fwiw it seems to work as expected with mode: "ROWCOUNT" and stats: "SMOOTH". I know that SMOOTH != LAST, but that's all that worked for me.
/ Constantine
ronyT1-VisitorAuthor
Hi Costantine,
Thank you for your answer.
You are correct, "SMOOTH" works fine and as expected. However, when I put mode to "LAST", it only takes the last value for one element and does not replicate that value if you have more than one consecutive empty value.
I am not sure if this is the real intention of the function or it is a bug in the function.
Thank you for your test
18-Opal
March 30, 2020
@ronyT, if you ask me, if something doesn't work as expected -- it's a bug (either in the code or in the docs).
/ Constantine
There are ways to do this, but like all interpolation methods, you need to have data at a scale smaller than the spatial scale of variations in the true surface being estimated. This is generally assumed, but not always correct. A good example is the problem with interpolating rainfall data.
