Jul 10, 2017 4:19 AM UTC
Invalid byte 1 of 1-byte UTF-8 sequence
Hi Folks,
I'm running TWX on 2 machines and exporting Entities from one to another but getting below error.
Error importing: error, Not Acceptable
"Internal error: com.sun.org.apache.xerces.internal.impl.io.MalformedByteSequenceException: Invalid byte 1 of 1-byte UTF-8 sequence"
*Both the machines have same TWX instance and configuration.
Any clues on this??
Tarun Nayyar
Jul 10, 2017 6:44 AM UTC
TanmeyTWX17-PeridotAuthor
Jul 11, 2017 4:44 AM UTC
Hi Carles,
Above case link referring to update Java settings of Tomcat.Unfortunately, I couldn't install tomcat through exe but a copy of installed directory of it.
Can you please let me know where I need to perform the below resoution. is it Catalina.sh or what?
make sure the Java settings for Tomcat include the following flag:
  • -Dfile.encoding=UTF-8
Jul 11, 2017 6:52 AM UTC
Hi Tarun,
It will depend on which operating system are you working...
But just do a web search on "how to change Tomcat Java options on XXX operating system and you will find it.
Best regards,
Carles.
