Ascherer17
Jul 17, 2026 4:07 PM UTC
IOT Streams, Kafka With Kerberos
We have a Kafka instance that utilizes Kerberos for authentication, and I want to set up an IOT Stream to push property data to it. I am successfully using Kerberos auth for a database connection from my Thingworx server (RHEL, Thingworx v10.1.1).  Do the Queue Providers support Kerberos authentication at this point?
The Help Center documentation doesn’t provide much guidance on what values I should use in the Configuration of my Queue Provider.  It also seems like the only authentication available is username/password-based.  After some research I tried using “SASL_SSL” for Security Protocol and “GSSAPI” for SASL Mechanism, but I get this error: Save failed: Failed to connect to [MyQP]. Reason: Failed to create new KafkaAdminClient
Any suggestions on getting the Queue Provider to utilize Kerberos authentication for connecting to my Kafka instance?
Help Center reference: https://support.ptc.com/help/thingworx/platform/r10.1/en/index.html#page/ThingWorx/Help/Composer/DataStorage/PersistenceProviders/ConfiguringaQueueProviderEntity.html
Support
Jul 28, 2026 8:42 PM UTC
Hi ​@Ascherer17
I checked around on this but wasn’t able to get an answer.  I think we’ll need to open a case so I can open a jira with R&D.
Please let me know if that is acceptable and I’ll be happy to open the case on your behalf.
--Sharon
Ascherer17
Jul 29, 2026 2:35 AM UTC
Yes, we can open a case to make the determination.
Support
Jul 29, 2026 3:28 PM UTC
Hi @Ascherer17.
I did find one other resource that may be able to help with this.  I’m waiting for his follow-up, so I’ll hold off on the case until I'm able to assess better whether a case will be needed.
--Sharon
Ascherer17
Jul 30, 2026 8:14 PM UTC
Further development:
After adding settings for the SSL keystore and Trust store and setting SASL mechanism to "GSSAPI/Kerberos", I'm now getting a timeout error in Composer:
Save failed: Failed to connect to [<myBootstrapServer:port>]. Reason: org.apache.kafka.common.errors.TimeoutException: Timed out waiting for a node assignment. Call: listNodes
I also see this WARN message in the Application log:
[AdminClient clientId=adminclient-28] Error connecting to node <myBootstrapServer:port> (id: -1 rack: null)
This seems like a step forward as the previous error stated “Failed to create new KafkaAdminClient” while this new WARN suggests an AdminClient was indeed created.  I further found if I change my SASL mechanism back to “GSSAPI”, I get the original  “Failed to create new KafkaAdminClient” error again.
Support
Aug 3, 2026 5:43 PM UTC
Hi ​@Ascherer17
Unfortunately, the R&D resource I talked with advised the code doesn’t support the configuration you’re trying to implement.  It would be an enhancement to the product to add it, so creating a ThingWorx Idea is the best approach forward.
--Sharon
