Is a ValueStream needed to plot historic values for a property?
Hi Everyone,
I have only been introduced to TWx 2 days ago, so please excuse if this is a stupid question:
I have defined a GenericThing-based Thing called "MyThing" with Integer property "MyProperty".
If I want to plot a graph on a Mashup (using the line graph widget), of the property "MyProperty", as it changed over time, would I need to somehow map a ValueStream to this property?
I have been trying to do this and I cannot figure out how to map the stream and property. I searched the tutorials and courses, but they don't show examples of this use-case.
Thank you in advance and kind regards,
Riaan
PaiChungAnswer
22-Sapphire I
You would need some sort of historical data store.
Value Stream or Stream is a structure that you can use.
It would be the easiest way for you to use a ValueStream and set logging to true and assign that valuestream to the Thing (then use QueryPropertyHistory services to pull data to display)
PaiChung22-Sapphire IAnswer
22-Sapphire I
riaanmarx1-VisitorAuthor
Thank you PaiChung!
And does this ValueStream then replace the Integer Property I already created on the Thing, or would you then somehow bind the two so that the property only return the current value?
22-Sapphire I
The property shows the value in real time.
enabling logging on the property will now store this value over time as it varies.
