Sep 5, 2017 4:40 AM UTC
Is it a bug? only double click datetime picker widget can be displayed ,one click should force close.
I use Thingworx 8,the problem is happen at Firefox or IE 11.
Sep 5, 2017 8:23 AM UTC
Hi Lianyi li, could you share exactly which datecode for ThingWorx 8 and bit more description about the issue? I just tried with 8.0.1 and i can use the dateTime picker without any issue.
lli-311-VisitorAuthor
Sep 12, 2017 1:32 PM UTC
Sushant Pandey,  Additional my tested mashup export file.
Sep 12, 2017 3:54 PM UTC
Thank you Lianyi, i'll check this out. Though unfortunately i will only be able to test it on EN OS. But will let you know of the test result.
Sep 5, 2017 9:14 AM UTC
lianyi li​ - I checked this on Thingworx 8.0 (IE 11) and also on the previous version 7.4.2 (IE 11) .This widget is working in same fashion on both cases .On single click it's opening up and you just select the date and press done for close .This is how it's is designed .If you need some custom feature you may take a copy of this widget and try some hands on .
Mukul Narang
