18-Opal
is it possible change user through mashup?
hi, i'm seonho
for example, i login 'A' User
and mashup has two text box and button(navigate)
a 'B' user ID and password  input to text box
and click button(navigate) then user change
it looks similar FormLogin
is it possible? if so how to?
thanks
PaiChungAnswer
22-Sapphire I
To my knowledge since you can only have one session at a time, you can't do it without first logging out one user then logging in as the other user.
(You can use a server side service to end a user session so it isn't just the logout service)
22-Sapphire I
What is the use case?
I've seen people create Registration style mashups using an AppKey which then allows a user to register first.
After that it logs them out and redirects them to a new page where they officially log in.
Is that what you are trying to accomplish?
I think if that is what you want to do?
Personally if you wanted someone to be logged out and another person be logged in, I would always do it in 'two steps' session closed, and they land at a login page.
CHASEONHO18-OpalAuthor
18-Opal
I'm sorry I did not give you enough explanation.
My intention is to be able to change users without logging out.
You can account in specific page(MashUp) using the AppKey.
The AppKey reference a user.
If you use AppKey to access a specific page, you will be logged in to Thingworx as a user referencing Appkey.
A good way to change a user is to sign out and redirect to a different login page.
But I wonder if I can change a user with a user ID and password without a widget called logout. (Service or event)
PaiChung22-Sapphire IAnswer
22-Sapphire I
