Is it possible to create a menu from script?
I want to create a Menu in Thingworx from script. I can create almost all other entities from script but I do not find a service to create a menu.
mneumannAnswer
No.
The EntityServices don't allow for creating a menu.
But I'll open an enhancement request for you on this one... seems like a good idea to me 🙂
Cheers,
Michael
mneumann16-PearlAnswer
No.
Cheers,
Michael
22-Sapphire I
You can however do a dynamic creation of a menu in runtime
or if you want to persist, you could create your content in a datatable
What is your use case for a persistent menu creation at runtime.
kornelius5-Regular MemberAuthor
The use case for this is that I use menus and sub-menus to structure my landing page similar to how the Navigate landing page looks like.
For future applications I want to add additional apps (tiles) through the menu structure.
Regarding the datatable: Is there a way to bind these to a menu?
22-Sapphire I
Yes Menu's can be data driven
So you can create a datatable based off the 'MenuItem' DataShape (plus some fields you need for administrative purposes)
and then when you pull that info from the datatable, you can then assign that to a Menu widget
