Arun_CAnswer
You need to create a new State Definition entity and need to define the State Information based on Value. And update that in shape widget.
8-Gravel
Emmm, sorry I found use slide bar as progress bar and add label widget on the top of it and bind same data of these two can achieve this goal.
Hi @Porcelain_ ,
You can use Shape Widget in 1 Contanier (required height & width & grey background) by pass numeric value to Data widget property and updating below given properties in widget you can achieve progress bar.
  • EnableDynamicFill  - True
  • DynamicFillOrientation - Horizontal
  • ShapeType - Rounded Rectangle
  • RectangleCornerRadius - As per requirement
  • Shape -State Definition (defined colors based value)
Expected Out:
Thanks & Regards,
Arun C
8-Gravel
Thanks! but can you show me the Shape -State Definition (defined colors based value please?
Because when I trying to do this but my shape always fulfill with same color.
螢幕擷取畫面 2024-01-11 163611.png螢幕擷取畫面 2024-01-11 163635.png螢幕擷取畫面 2024-01-11 163647.png螢幕擷取畫面 2024-01-11 163705.png
Here is my result.
