Jul 4, 2016 9:05 AM UTC
Is it possible to "cut" part of a widget in mashups?
As you can see in the image, I'm using only 180 degrees of the gauge widget. I would like to ask, is it possible to cut out the unused half?
I'd like to have a widget like this:
Jul 4, 2016 9:32 AM UTC
To do it, I've set the background color for the widget with the same background color as background. Maybe also you can put a Rectangular Shape widget over the bottom
fmanniti1-VisitorAuthor
Jul 4, 2016 10:31 AM UTC
It's the same clue I had; I just don't like it too much and I hoped there was a more "elegant" way to do it.
Sorry for the OT question but do you know if is there a way to set the scale counterclockwise?
I opened a topic about this but the answer I got was about try to play with properties of the widget, but I did and it doesn't seem to work
Jul 4, 2016 10:36 AM UTC
About Counterclock I don't know, did you tried to set Minimum with the Bigger Value and Maximum with the Lower Value?
