Is it possible to extract stream data into an excel file?
Is it possible to extract all the table from the service GetStreamEntriesWithData into an excel (or other) file?
If you want to do it Server Side onto a File Repository, you can use one of this  extensions:
You can save files directly to the File Repository without any extension too, with FileRepository.WriteToTextFile Service
Google Drive:
None of these links works, all get 404 error
22-Sapphire I
Client Side you can use the Data Export Widget or from either client or server side you can use the REST API with Accept=text/csv
