Is it possible to highlight complete column based on column name?
Am displaying a grid with 24 hrs data, want to highlight columns based on user selection. Selection happening by range slider.
Ex,
User can select  From and To hours b/w 1-24 by range slider, based on the selection grid columns should be highlighted. Grid column name are like 1,2,3,..24
Regarding
Janakiraman P
RaduAnswer
You did not use the x variable in the for loop. I assume it is the row index for the infotable. What is the datashape of alldata? Does it contain all 48 columns? If so, try accessing the elements through alldata[x][colArray[index-1]].
Also if you are working with booleans, you shouldn't enclose true between apostrophes.
I don't believe it is possible to colour specific cells within a row, only the whole row itself.
You might consider a service that filters the grid columns in such a way that the only columns shown are the ones specified in the range slider. Is this approach good for your solution?
Am having an idea to make it possible.
I have 48 columns in the datashape, first 24 are actual columns and next 24 are duplicate of first.
Ex, one,two,three...twentyfour     then  one_1,two_2,three_3...twentyfour_24
based on value of one_1(true/false) state definition can be applied on column one.
Based on the user input range am writing the following code to update the infotable.
user input variables are, from=2  to=5
var alldata = Things["R_n_D_John"].GetDataTableEntries({
maxItems: undefined /* NUMBER */
var colArray=['one_1','two_2','three_3','four_4','five_5','six_6','seven_7','eight-8','nine_9','ten_10','eleven_11','twelve_12','thirteen_13','fourteen_14','fifteen_15','sixteen_16','seventeen_17','eighteen_18','nineteen_19','twenty_20','twentyone_21','twentytwo_22','twentythree_23','twentyfour_24'];
for(var x=0;x<alldata.getRowCount();x++){
for(var index=from;index<=to;index++)
alldata.colArray[index-1]='true';
result=alldata;
but am getting a different error now. getting the following error.
Error executing service filteredData. Message :: TypeError: Cannot set property "1" of undefined to "true" - See Script Error Log for more details.
help me to resolve the error if possible.
Janakiraman P
Radu15-MoonstoneAnswer
