Is it possible to set line break for Tooltip message of ThingWorx Button widget?
Is it possible to set line break for Tooltip message of ThingWorx Button widget? Any css available for new line ?
slangleyAnswer
Support
Hi @AP_10343008.
We played around with this a little but were unable to find a solution.  Perhaps someone else in the community has found a way to do this.
You can submit a request for this on the ThingWorx Ideas forum, which will allow others to vote for it.
--Sharon
22-Sapphire I
I think I've seen this done unfortunately I forget where, but I think ...
If you can dynamically bind a value to the tooltip, you can use an expression to generate it with a "text" + /r (or /n + "text" I think ...
3-Newcomer
Tried to bind the tooltip fied dynamically, it's working if i am binding it with textfield widget, but as a tooltip message i am not getting it in new line. could you please some other way to do it?
slangleyCommunity ManagerAnswer
Support
Hi @AP_10343008.
--Sharon
