Is it possible to show the external .jsp pages in Thingworx Composer Mashup?
Is it possible to show the external .jsp pages in Thingworx Mashup or can we use the .jsp tags/whole jsp code in Thingworx Composer JavaScript services?
slangleyAnswer
Support
Hi @hbavirisetti .
Per the outcome of the case, it was determined that we do not support inclusion of jsp. However if you want a java specific code or a UI specific code to be included, you can develop a custom extension/widget.
If you feel this provides an answer to your question, please mark this reply as the Accepted Solution.
--Sharon
@hbavirisetti  I believe you have a PTC case opened for this request and we will be addressing this query under the same case.
Vibhuti
slangleyCommunity ManagerAnswer
Support
Hi @hbavirisetti .
--Sharon
