Jun 21, 2016 2:47 PM UTC
Is it possible to trigger a raspberry pi with data from the ThingWorx platform?
Hello everybody,
I want to address some raspberry pi's with data from the ThingWorx platform.
Is this possible in general ? And if, how can I do that?
Thank you in advance
Have a nice day
Matthias
Jun 30, 2016 3:20 PM UTC
Hello, what exactly are you asking? Would you like to connect a Raspberry Pi to ThingWorx Composer?
Have you seen this tutorial? Weather Applications with Raspberry Pi - ThingWorx : ThingWorx
Thanks!
Tori
Aug 17, 2017 1:11 AM UTC
So this is an interesting question and its something that I'm also trying to get working.
I have the following setup.
1. Raspberry pi 3 with sense hat.
2. VM with TWX8, mfg_apps loaded and Kepware.
In kepware i can set the value of a property using the Asychronous 2.0 Write
And that works quite well to read a message accross the sense hat and show a picture, (both predefined)
I have also made that property in Thingworx and set the value to evoke the same thing.
(so essentially this works as long as I'm connected to kepware and i have saved the thing etc etc etc.)
The scenario I want to test now is with without kepware
I have a simple python script that waits for input from the user and then once it is received it runs it.
like this.
prompt = raw_input ("enter your message: ")
sense.show_message (prompt )
I want to be able to have a mashup where I can enter a random text string like "bob was here" and that will display on the sense hat.
Please let me know if you need more detail.
Regards
Bryan
Aug 21, 2017 4:39 PM UTC
Greetings Bryan,
It looks like you followed the steps to configure the Sense Hat laid out in the Sigma Tile Workshop, here:
Sigma Tile Workshop Guide.pdf
Part of that setup involves installing the Python library 'pymodbus' to implement the Modbus protocol on the Raspberry Pi. The Raspberry Pi was then able to fulfill the function of a Modbus Slave, which was how the KEPServerEX Modbus TCP/IP Ethernet Driver interfaced as the Modbus Master. This configuration is a great example of a solution involving KEPServerEX and ThingWorx. KEPServerEX enables connectivity to many Industrial Automation protocols, with Modbus being one of the most widely used.
There is a discussion of alternate scripts that can be used to interface the Raspberry Pi/Sense Hat directly with ThingWorx, which can be found in the ThingWorx Developer Community, here:
Re: Thingworx and EMS
Please let us know how it goes with trying out the suggestions in that thread.
Best regards,
Steven M
