Is the alert example code on this page still valid as of 8.4?
https://support.ptc.com/cs/help/thingworx_hc/thingworx_7.0_hc/index.jspx?id=thingworx0303&action=show
At the bottom of this page there is an example of how to add or edit an alert for a given property. However when I try and implement this I get the error: "Error executing service AlertAddUpdate. Message :: Alert Attributes For [Above] are not valid - See Script Error Log for more details."
The only attributes we need to set are the limit and the limit inclusive if I'm correct, so why would I be getting this error message? I have changed the property variable name to a property on the thing where I am implementing this service.
// Create the Attributes Infotable for AddOrUpdateAlert call
var params = {
	infoTableName: "alertAttr" /* STRING */
var attrs = Resources["InfoTableFunctions"].CreateInfoTable(params);
// Define the fields required by an Above type Alert for an INTEGER field (not the values!)
// limit - Minimum value at which the alert will trigger.
var field = new Object();
field.name = "limit";
field.baseType = 'INTEGER';
attrs.AddField(field);
// limitInclusive - Is the condition Greater than (>) or Greater than or equal (>=)?
field.name = "limitInclusive";
field.baseType = 'BOOLEAN';
// Define the new Alert values and add the row to the table.
var row = new Object();
row.limit = 5;					// Alert will trigger when field >=5
row.limitInclusive = true;		// Alert includes 5
attrs.AddRow(row);
// Call the AddOrUpdateAlert Service
var params = {
	alertType: "Above" /* STRING */,
	alertName: "MyAlert" /* STRING */,
	property: "Sensor_Value2" /* STRING */,
	attributes: attrs /* INFOTABLE */,
 	priority: 1 /* INTEGER */,
	persistent: true /* BOOLEAN */,
	enabled: true /* BOOLEAN */
me.AddOrUpdateAlert(params);
This is my code just for reference.
Jon
AnnaAnAnswer
Attached the entity file.
22-Sapphire I
Any more info in the logs in regards to the error?
The logs are about as helpful as you'd expect - "[message: Execution error in service script [AlertAddUpdate] :: Alert Attributes For [Above] are not valid]"
22-Sapphire I
I guess it is saying that the attributes you specified for Above are wrong. I would pull the attributes from an existing alert to check if either you have it incorrect or if it has changed.
Maybe a spelling issue?
