Is there a way to change string to Location data type ?
Hi All,
I am getting Lat and Long of a plant location  from Database which are of VARCHAR . I am trying to convert them to Location datatype in Thingworx, but getting following error.
Unable To Convert From java.lang.String to LOCATION
Can someone help me on this ?
Location is a little bit more complex base type. It is actualy a JSON with 4 Objects:
  • latitude
  • longitude
  • elevation
  • units
Like this:
 "location": {
 "latitude": 0.1111,
 "longitude": 0.2222,
 "elevation": 0.3333,
 "units": "WGS84"
So iff you want to change its value in ThingWorx JS code you should create new Location property and assing value like it would be a JSON:
me.myLocationProperty = {
 "latitude": 50,
 "longitude": 50,
 "elevation": 50
You can now change 50, 50 & 50 hardcoded values to your paramaters from VARCHAR.
Best,
Adam
Thanks, Adam
