Oct 5, 2023 3:47 PM UTC
Is there a way to change the color of the gauge value, face or needle based on a dynamic value?
I have a gauge that I need to change the color of something based on if the value in the gauge is above or below a target value. The target value is constantly changing so it needs to be dynamic. I create different CSS classes, and then pass the class it should look at, but I am not sure how to properly write the CSS that would change the face of the gauge face, needle, or value color.
Thanks!
ThingWorx 9.3.8
Oct 10, 2023 1:30 PM UTC
I just simply removed the gauge ID element it is is now working.
.gaugeGreenColor svg > circle:nth-child(5)
fill : green;
stroke : red;
.gaugeRedColor svg > circle:nth-child(5)
fill : red;
stroke : green;
Thank you for your help!
Oct 6, 2023 7:27 AM UTC
Hi @MG_9567080
You can change the color of the Needle using the ValueFormatter property
To change face color you need to create a custom CSS
Step 1: Create Custom CSS for different color
.gaugeGreenColor #root_gauge-80-widget-gauge-container > svg > circle:nth-child(5)
 fill : green !important;
 stroke : green !important;
.gaugeRedColor #root_gauge-80-widget-gauge-container > svg > circle:nth-child(5)
 fill : red !important;
 stroke : red !important;
Replace "gauge-80" with your mashup gauge ID number, You can find the ID in Developer tool
Step 2: Create an expression to return the Custom CSS class based on the input
Step 3: Bind expression output to gauge widget custom CSS property
It should look like this:
/VR
Oct 9, 2023 4:36 PM UTC
So this is working when I have the gauge only in the Mashup, however it does not work if I have the gauge mashup as part of an embedded mashup or part of a collection.
Oct 10, 2023 6:39 AM UTC
Hi @MG_9567080
You need to provide the correct element ID in the CSS to work.
If possible could you please share your collection mashup / embedded mashup. I can try finding guage ID in mashup and fix it.
/VR
