Oct 16, 2024 8:23 AM UTC
Is there any possible ways to edit the cell only for newly adding rows in adv-grid ?
In adv-grid, I have enabled 'EnableEditButtons' and 'IsEditable' in advanced grid widget and In 'Configure Grid Columns' 'IsEditable' is selected for few columns. Then,
In UI, If user selecting ADD button to add rows in grid, there are any possible ways to edit the cell only for newly adding rows ?
18-Opal
Oct 22, 2024 4:58 PM UTC
Not the best solution, but you can split it into two grids -- a read-only one for the existing data and an editable one for newly added rows. You can call it "review staged changes before saving them" and pretend it's a feature.🙂
/ Constantine
Oct 16, 2024 12:32 PM UTC
Hi, @AP_10343008  Your use-case looks like needs a custom service, look at the below article if it helps then good otherwise try to achieve it by customization.
https://www.ptc.com/en/support/article/CS391327
Oct 16, 2024 12:46 PM UTC
My requirement is to make first 5 rows of ColumnA cells non-editable. And remaining rows of same columnA editable. Is this can be achieved by configuration json ?
Oct 22, 2024 10:21 AM UTC
Hi @AP_10343008  You can create a custom widget for this.
18-Opal
/ Constantine
Oct 22, 2024 5:41 PM UTC
Yeah its a good idea. Thanks.
