Is there there something from thingworx for url parsing?
Hello Team,
Is there any url parsers in thingworx and if not can we have any .js url parsers extension imports  available?
22-Sapphire I
Are you looking to build some sort of load balancer / redirect / redistribution system?
What is your use case?
vijay51-VisitorAuthor
Thanks for the reply
For a service that will accept url and depending on the ip address and port need to take action to support multiple system feeds
22-Sapphire I
I don't think that will be easy to support within Thingworx.
Can you at all supply that information in the headers of your call?
You would set up a Service in thingworx with the required input parameters
that automatically becomes an exposed REST API point
Then the other systems can call that with the parameters either in the URL or Best Practice in the headers/body of the call
