Dec 5, 2016 4:40 PM UTC
Issue in connecting Thingworx and Modbus PLC Simulator
Hi All,
  • I am running Modbus PLC simulator (downloaded from Modbus PLC Simulator​) and Thingworx server on windows machine.
  • Running EMS on Raspberry pi (all are connected in same network)
  • I am using MicroServer-5.3.2-Linux-ARM-HWFPU and Modbus package for LinuxARM
I am following modbus example from Modbus PLC Simulator, ThingWorx and You
This is my ws_servers & auto_bind section of config.json
  "ws_servers": [ {
       "host": "192.168.0.94",
       "port": 8443
  "appKey": "9311c13b-69a1-49fa-9e22-00bd9fe8c333",
  "auto_bind": [ {
       "name": "ModbusGateway",
       "gateway": true
and config.lua
scripts.MyPLC = {
    file = "thing.lua",
    template = "modbusExample",
    identifier = "plc",
    updateRate = 2000
scripts.Thingworx = {
    file = "thingworx.lua"
scripts.modbus_handler = {
    file = "modbus_handler.lua",
    name = "modbus_handler",
    host = "192.168.0.94",
    port = "502"
The problem is that I can bind remote properties to a created thing but could not able to read modbus registries.
I am getting following error.
pi@raspberrypi:~/microserver/install_services $ sudo journalctl --unit=tw_luaScriptResourced | tail -20
Oct 21 15:36:01 raspberrypi thingworx[5648]: ScriptResource::executeScriptRequest:Path /scripts/modbus_handler/holding_register/1/40001/ not found
Oct 21 15:36:01 raspberrypi thingworx[5648]: luaInterscriptBinding::l_executeCallback:Error executing callback 'modbus_handler//scripts/modbus_handler/holding_register/1/40001'
                                             Returned: 404 /scripts/modbus_handler/holding_register/1/40001/ not found
Oct 21 15:36:01 raspberrypi thingworx[5648]: MyPLC:Could not read current value of Int16HoldRegExample. Setting quality to UNKNOWN. Resp:
Oct 21 15:36:01 raspberrypi thingworx[5648]: MyPLC:Error while getting property Int16HoldRegExample. msg: /scripts/modbus_handler/holding_register/1/40001/ not found
Oct 21 15:36:04 raspberrypi thingworx[5648]: ScriptResource::executeScriptRequest:Path /scripts/modbus_handler/holding_register/1/40001/ not found
Oct 21 15:36:04 raspberrypi thingworx[5648]: luaInterscriptBinding::l_executeCallback:Error executing callback 'modbus_handler//scripts/modbus_handler/holding_register/1/40001'
Oct 21 15:36:04 raspberrypi thingworx[5648]: MyPLC:Could not read current value of ScaledInt16RegExample. Setting quality to UNKNOWN. Resp:
Oct 21 15:36:04 raspberrypi thingworx[5648]: MyPLC:Error while getting property ScaledInt16RegExample. msg: /scripts/modbus_handler/holding_register/1/40001/ not found
Oct 21 15:36:04 raspberrypi thingworx[5648]: ScriptResource::executeScriptRequest:Path /scripts/modbus_handler/holding_register/1/40002/ not found
Oct 21 15:36:04 raspberrypi thingworx[5648]: luaInterscriptBinding::l_executeCallback:Error executing callback 'modbus_handler//scripts/modbus_handler/holding_register/1/40002'
                                             Returned: 404 /scripts/modbus_handler/holding_register/1/40002/ not found
Oct 21 15:36:04 raspberrypi thingworx[5648]: MyPLC:Could not read current value of Uint16RegExample. Setting quality to UNKNOWN. Resp:
Oct 21 15:36:04 raspberrypi thingworx[5648]: MyPLC:Error while getting property Uint16RegExample. msg: /scripts/modbus_handler/holding_register/1/40002/ not found
Oct 21 15:36:04 raspberrypi thingworx[5648]: MyPLC:Could not read current value of Int16HoldRegExample. Setting quality to UNKNOWN. Resp:
Oct 21 15:36:04 raspberrypi thingworx[5648]: MyPLC:Error while getting property Int16HoldRegExample. msg: /scripts/modbus_handler/holding_register/1/40001/ not found
am I missing something?
2nd query is how to log the messages from luaScriptResource when its running as service? config.lua does not have logger section.
Do1Answer
Jan 13, 2017 6:56 PM UTC
Hello Mithun,
I recently found some industrial units based on the Raspberry Pi and were quite excited about the possibilities.
Unfortunately I encountered the same issues with both my standard Raspberry Pi and these new ones.
I identified two problems on my side:
1. The modbusExample.lua tries to load file transfer functionality.
2. There is something wrong with the supplied core.so file (maybe it was not compiled for ARM architecture) - you get No such file or directory
[ERROR] when running the luaResource.
To fix the 1st issue is easy... just remove the require "thingworx.shapes.filetransfer" line from modbusExample.lua.
To fix the second issue you need to find a core.so file which is compatible with the ARM Architecture of your Raspberry Pi.  In theory, the core.os file supplied as part of the TWEMS MODBUS Package_Linux_ARM.zip file located at microserver/etc/community/clibs/socket/core.so should work, but it does not.
Download the lua-socket resource:
$ sudo apt-get install lua-socket
Copy the newly downloaded core.so to your microserver installation:
$ cp /usr/lib/arm-linux-gnueabihf/lua/5.1/socket/core.so /home/pi/microserver/etc/community/clibs/socket/
Now if your config files are configured correctly, then everything should work.
Good luck!
Dec 5, 2016 7:47 PM UTC
Mithun, can you output the luaScriptResource onto a log file by running the following?
luaScriptResource > logfile.log
When you run both the EMS and lua, does the Modbus sim show a successful connection?
msarage1-VisitorAuthor
Dec 5, 2016 8:45 PM UTC
Ravi,
When i type the command
  i get following error.
luaScriptResource: command not found
Sorry I am new to Linux.
Yes When I run EMS & Lua services, in Thingworx I can see Identifier for remote thing also I can browse remote properties, only thing is values are not getting updated.
When I type the command
sudo journalctl --unit=Thingworx_Lua | tail -50          (here Thingworx_Lua is my service name from lua script)
get following result
pi@raspberrypi:~/microserver/install_services $ sudo journalctl --unit=Thingworx_Lua | tail -50
Oct 21 19:34:44 raspberrypi thingworx[3844]: luaInterscriptBinding::l_executeCallback:Error executing callback 'modbus_handler//scripts/modbus_handler/holding_register/1/40001'
Oct 21 19:34:44 raspberrypi thingworx[3844]: luaInterscriptBinding::l_executeCallback:Error executing callback 'modbus_handler//scripts/modbus_handler/holding_register/1/40002'
Oct 21 19:34:47 raspberrypi thingworx[3844]: luaInterscriptBinding::l_executeCallback:Error executing callback 'modbus_handler//scripts/modbus_handler/holding_register/1/40001'
Oct 21 19:34:47 raspberrypi thingworx[3844]: luaInterscriptBinding::l_executeCallback:Error executing callback 'modbus_handler//scripts/modbus_handler/holding_register/1/40002'
Oct 21 19:34:50 raspberrypi thingworx[3844]: luaInterscriptBinding::l_executeCallback:Error executing callback 'modbus_handler//scripts/modbus_handler/holding_register/1/40001'
Oct 21 19:34:50 raspberrypi thingworx[3844]: luaInterscriptBinding::l_executeCallback:Error executing callback 'modbus_handler//scripts/modbus_handler/holding_register/1/40002'
Oct 21 19:35:05 raspberrypi systemd[1]: Stopping LSB: ThingWorx Lua Script Resource...
Oct 21 19:35:05 raspberrypi logger[3904]: Stopping ThingWorx Lua Script Resource luaScriptResource
Oct 21 19:35:05 raspberrypi Thingworx_Lua[3899]: start-stop-daemon: warning: this system is not able to track process names
Oct 21 19:35:05 raspberrypi Thingworx_Lua[3899]: longer than 15 characters, please use --exec instead of --name.
Oct 21 19:35:21 raspberrypi thingworx[3844]: HttpClient::processReq:Timeout while waiting for response from localhost.
Oct 21 19:35:21 raspberrypi thingworx[3844]: luaBindings::httpPost:Error POSTing to HTTP Server at localhost/Thingworx/Things/LocalEms/Services/HasEdgeThing
Oct 21 19:35:35 raspberrypi systemd[1]: Stopped LSB: ThingWorx Lua Script Resource.
Oct 21 19:35:48 raspberrypi systemd[1]: Starting LSB: ThingWorx Lua Script Resource...
Oct 21 19:35:48 raspberrypi logger[3944]: Starting ThingWorx Lua Script Resource luaScriptResource
Oct 21 19:35:48 raspberrypi thingworx[3948]: daemonize:Child process running
Oct 21 19:35:48 raspberrypi thingworx[3948]: psrap::daemonize:Child creating session id...
Oct 21 19:35:48 raspberrypi thingworx[3948]: psrap::daemonize:Child continuing...
Oct 21 19:35:48 raspberrypi thingworx[3948]: psrap::daemonize:Child closing out stdin,stdout,stderr...
Oct 21 19:35:48 raspberrypi thingworx[3948]: /home/pi/microserver/install_services/..//luaScriptResource:Using config file: /home/pi/microserver/install_services/..//etc/config.lua
Oct 21 19:35:48 raspberrypi thingworx[3948]: /home/pi/microserver/install_services/..//luaScriptResource:Starting up ....
Oct 21 19:35:48 raspberrypi logger[3949]: 0
Oct 21 19:35:48 raspberrypi systemd[1]: Started LSB: ThingWorx Lua Script Resource.
Oct 21 19:35:48 raspberrypi thingworx[3948]: luaScriptProxy::execute:[1972368464] Error executing script modbus_handler, Error = Error: error loading module 'socket.core' from file '/home/pi/microserver/install_services/..//etc/community/clibs/socket/core.so':
                                                    /home/pi/microserver/install_services/..//etc/community/clibs/socket/core.so: cannot open shared object file: No such file or directory
Oct 21 19:35:48 raspberrypi thingworx[3948]: luaScriptProxy::app_unlock:[1972368464] Attempt to unlock app_mutex while not holding it.L= 0x759144e8
Oct 21 19:35:48 raspberrypi thingworx[3948]: httpServer:starting http server port=502
Oct 21 19:35:48 raspberrypi thingworx[3948]: httpserver:Server socket error: Address not available [192.168.0.94:502]
Oct 21 19:35:48 raspberrypi thingworx[3948]: httpServer:unable to bind http server to any port from 502 to 502.
Oct 21 19:35:51 raspberrypi thingworx[3948]: luaInterscriptBinding::l_executeCallback:Error executing callback 'modbus_handler//scripts/modbus_handler/holding_register/1/40001'
Oct 21 19:35:51 raspberrypi thingworx[3948]: luaInterscriptBinding::l_executeCallback:Error executing callback 'modbus_handler//scripts/modbus_handler/holding_register/1/40002'
Oct 21 19:35:51 raspberrypi thingworx[3948]: luaInterscriptBinding::l_executeCallback:Error executing callback 'modbus_handler//scripts/modbus_handler/holding_register/1/40003'
                                            Returned: 404 /scripts/modbus_handler/holding_register/1/40003/ not found
In this this result I feel these are the lines which are hinting something
I am using following EMS and modbus package
MED-61060-CD-053_SP2_Microserver-5-3-2-Linux-ARM-HWFPU.zip
Dec 5, 2016 9:41 PM UTC
You would need to stop the lua service, navigate to /home/pi/microserver (assuming that's where the luaScriptResource file is) and then run ./luaScriptResource > log.log
That should pipe the output onto the log file. Going by this message -
Is the sim actually running/ connected? If you have the EMS and lua running, and along with the sim, the sim should say something on the lines of Connected (1/10) to show successful connection via port 502 (default port).
