Issue while Connecting MS SQL Server with Thingworx
I am trying to connect SQL Server (Installed on my laptop) with ThingWorx (manufacturing APP). I am facing this error when trying to execute the service. I am using Windows authentication to log into the SQL Server so I am not setting any Username and Password in the Configuration of Thing.
Support
Hi @Harsha616.
When you say you are trying to connect SQL Server with ThingWorx, are you saying you are trying to configure SQL Server as a data provider?  If so, take a look at the Relational Database Connectors available on PTC Marketplace.
You also may need to run SQL Server in mixed authentication mode, and set up a SQL Server user for accessing your data.
--Sharon
Harsha6161-VisitorAuthor
Hi slangley,
Thanks for your reply, I have downloaded the MSSQL and JDBC connectors from the PTC Marketplace and imported them using composer. I also tried creating a new user in MS SQL Server still getting the same error. Sharing the configuration details below for your reference.
I also tried changing the authentication mode to "SQL Server Authentication" but still getting error.
JDBC Driver Class Name: com.microsoft.sqlserver.jdbc.SQLServerDriver
JDBC Connection String: jdbc:sqlserver://localhost;databaseName=Coffee
connectionValidationString: SELECT GETDATE()
Database User Name: TWAdmin   ---(Created a user in SQL Server)
Support
Hi @Harsha616.
Your connection string is missing the port.  The default for SQL Server is 1433 but, of course, this can be changed so you will need to validate for your implementation.
--Sharon
