Mar 28, 2025 12:59 PM UTC
Issue with Scheduler Time Update Not Reflecting in Production
I recently updated the scheduler time in our development environment, but the changes have not been reflected in the production environment.
What is the reason this ?How can I track the issue.
nmutterAnswer
Mar 28, 2025 3:03 PM UTC
how is the sync process between DEV and PROD? not sure why you expect a change done in DEV should change something in PROD?
General Info: Scheduler from an extension will not override its settings when importing a new version with a new schedule. The scheduler settings are stored in a configuration table of the Scheduler-Thing. Which has the same behavior like other configuration tables. Also see https://www.ptc.com/en/support/article/CS392575 regarding the Configuration-table behavior.
nmutter17-PeridotAnswer
Support
Apr 8, 2025 2:00 AM UTC
Hi @SD_10134497 ,
It appears that a response to this post answers your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
