Issues displaying Dynamic Image
Hey guys,
I've reviewed some posts in the forums that are relevant to my issue - Such as "How to set image in media entity dynamically?" that was posted by done11.  I am currently facing an issue with my dynamic media entity.
I have followed this code snippet:
var params = {
  url:  'https://pbs.twimg.com/profile_images/447374371917922304/P4BzupWu.jpeg' /* STRING */,
// result: IMAGE
var image = Resources["ContentLoaderFunctions"].LoadImage(params);
var params = {
  name: 'TestMedia'/* STRING */,
  content: image
// no return
Resources["EntityServices"].UpdateMediaEntity(params);
I have set up a template thing that is referencing a file repository base thing template, then I proceeded to create a thing with the service(baseType ImageLink) mentioned above. I created a "dynamic" media entity that has a corresponding name to my service. I bound the service from my thing to the media entity but I have no image displaying currently upon runtime.
I have also tried changing the baseType to Image and linking the data to a value display, but this method did not work either.
Here are the errors that I receive:
Error from the server: "Wrapped java.net.SocketException: Software caused connection abort: recv failed Cause: Software caused connection abort: recv failed"
Any help would be appreciated.
Thanks.
Is there a specific reason you're trying to use a media entity when you can just use an image widget and bind the output of your service (with a few modifications) to the image widget?
