It is possible to add mysql jdb driver to thingworx trial edition ?
I have Thingworx Trial Edition (Docker)
I need to connect to mysql server, but I can't install Relational Databases Connectors  extension due to conflict with PostgresSql
Is there any solution ?
zyuan1Answer
Haven't seen this error before, do you have the screenshot for this error message?
There's also another extension you can use, and you can search for JDBC connector extension in the Market Place.
zyuan15-Regular MemberAnswer
hi @bakrim just to be sure are you importing the entire Relational Database Connectors zip or just the zip for MySQL?
