Iterating through an array of infotable collection and export the infotable elements to excel
I have a collections of infotable as shown below. Each table has different column structure and no tables are same. Now I need to iterate through each infotable and export the data as a excel report.
using the snippet.
let params = {
infotable: undefined /* INFOTABLE */
};// result: STRING
let result = Resources["InfotableExporterFunctions"].ExportInfotableAsExcel(params);
Kindly assist
VelkumarAnswer
Hi @SK_10752382
Please find below code:
I have a dummy input
Code to combine all tables into a single InfoTable
// Dummy Input
var dummyInputInfoTable = me.dummyInput();
/* Find maximum number of fields in Table */
var maxFieldCount = 0;
var tempInfoTable = null;
var tempInfoTableFields = null;
// Iterate over each infoTable from input
let dataShapeFields = dummyInputInfoTable.dataShape.fields;
for (let fieldName in dataShapeFields) {
	tempInfoTable = dummyInputInfoTable[fieldName];
	tempInfoTableFields = tempInfoTable.dataShape.fields;
	var tempFieldCount = Object.keys(tempInfoTableFields).length;
	if (tempFieldCount > maxFieldCount) {
		maxFieldCount = tempFieldCount;
/* Create result infoTable to store data */
let params = {
	infoTableName: "result" /* STRING {"defaultValue":"InfoTable"} */
// result: INFOTABLE
let result = Resources["InfoTableFunctions"].CreateInfoTable(params);
// Add fields to result infoTable
for (var i = 0; i < maxFieldCount; i++) {
	result.AddField({
		name: "field" + (i + 1),
		baseType: "STRING"
	// Add Fields into result infoTable
	var fieldCount = 0;
	var fieldValues = new Object();
	for (let fieldName in tempInfoTableFields) {
		fieldValues["field" + (fieldCount + 1)] = fieldName;
		fieldCount++;
	result.AddRow(fieldValues);
 // Add data into result InfoTable
 for(var infoLength = 0; infoLength < tempInfoTable.length; infoLength++)
 var dataValues = new Object();
 var dataFieldCount = 0;
 for (let fieldName in tempInfoTableFields){
 dataValues["field" + (dataFieldCount + 1)] = tempInfoTable[infoLength][fieldName];
 dataFieldCount++;
 result.AddRow(dataValues);
Expected Output :
/ VR
Hi @SKannapiran
Could you please provide some sample data and how exactly Excel should look.
Because I can see each info table has a different row count how do you want to manage those into a single Excel sheet.
If fieldNames are not defined or dynamic, you can iterate over fieldName to populate data
// infotable datashape iteration
let dataShapeFields = yourInfotableHere.dataShape.fields;
 //logger.warn('field name is ' + dataShapeFields[fieldName].name);
 //logger.warn('field basetype is ' + dataShapeFields[fieldName].baseType);
Please provide some sample data it will help us to understand requirements better.
Thanks.
VR
Dear @Velkumar ,
I have attached an excel workbook, having multiple sheets (Table0, Table1, Table2, Expected_Result)
Each tab represents an infotable with static columns. The expected result is shown in the last tab.
Hope this answer to your request.
Velkumar19-TanzaniteAnswer
Hi @SK_10752382
// Dummy Input
let params = {
	result.AddField({
		baseType: "STRING"
	var fieldCount = 0;
		fieldCount++;
 dataFieldCount++;
Expected Output :
/ VR
