java sdk
How to use Service developed using Java extension in Thingworx Service?
I want to use Service present in Extension in Thingworx service.
slangleyAnswer
Support
Hi @AR_07.
So basically, you want to call your custom service from another entity, correct?  If so, this article may be helpful.
If we're not understanding, please provide more details.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @AR_07.
--Sharon
@Test_user,
If you have created an Extension to ThingWorx. That extension might have created definition of a ThingTemplate. This template will be used in defining a new thing. The services which are created from JAVA code are then available.
Let me know where you are in this process and I will provide direction.
