java sdk not working with docker
I was trying to use the Thingworx java sdk with docker to build an image out of it and use it as a docker container. I followed the following steps:
1) I loaded the application into eclipse
2) I ran gradel build gradle Build from eclipse which exported the app as a jar
3) I built an image using "docker build -t imagename ." in the directory of the jar
4) docker run imagename
This throws an error saying mainclass not found
I tried running the jar exported using java -jar filename.jar That throws the same error. Below is my build.gradle file
Install gradle at https://gradle.org/ and execute 'gradle run' or 'gradle SimpleClient'
in this directory to run an example. Other examples can be run
with the commands 'gradle SimpleThing' and 'gradle Steam'.
You can also generate an Eclipse project with the command 'gradle eclipse' or
install the gradle eclipse plugin from the Eclipse Marketplace and Import it into eclipse.
apply plugin: 'java'
apply plugin: 'application'
//apply plugin: 'docker'
apply plugin: 'eclipse'
sourceCompatibility = 1.7
targetCompatibility = 1.7
version = '1.0'
mainClassName = "com.thingworx.sdk.simplething.SimpleThingClient"
// Customize the settings below to run the SteamClient
project.ext {
serverUrl = "ws://localhost:8080/Thingworx/WS"
appKey = "f5966263-ea1b-4ebf-ae0a-8467fa65469c"  // Create this in Thingworx xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
scanRate = "1000" //ms
numberOfSensors = "10" // The number of sensors to create
startSensor = "1" // The starting number for the first sensor
jar{
manifest {
        attributes ('Main-Class': 'com.thingworx.sdk.simplething.SimpleThingClient.class')
sourceSets {
main {
java {
srcDir 'src'
resources {
srcDir 'resources'
buildscript {
  repositories {
    //this plugin will be pulled from jcenter
    jcenter()
dependencies {
compile fileTree(dir: '../lib', include: ['*.jar'])
//classpath 'se.transmode.gradle:gradle-docker:1.2'
task SimpleClient(type: JavaExec) {
dependsOn "build"
classpath = sourceSets.main.runtimeClasspath
main = "com.thingworx.sdk.simple.SimpleClient"
task SimpleThing(type: JavaExec) {
dependsOn "build"
main = "com.thingworx.sdk.simplething.SimpleThingClient"
task Steam(type: JavaExec) {
dependsOn "build"
main = "com.thingworx.sdk.steam.SteamSensorClient"
args project.ext.serverUrl,project.ext.appKey,project.ext.scanRate,project.ext.startSensor,project.ext.numberOfSensors
Below is the error message (This is the only line that prints)
"Error: Could not find or load main class com.thingworx.sdk.simplething.SimpleThingClient.class"
using same process other apps that I worked on previously not involving Thingworx does not throw this issue
Hello, Rishit Shah.
I'm not familiar with the gradle plugin but I did notice this:
Should the Docker plugin be commented out here when doing the build?
-- Craig A.
rshah11-VisitorAuthor
Hi Craig,
Yes I commented that out on purpose as it was throwing another error saying "plugin not found". I used a workaround instead and tried built the image including the jar exported from this gradle file. But then I ran into the above issue.
Hi @rshah1,
did you find a solution for your problem? i have the same issue, i'm using gradle with the sdk java example :
=> java -jar sample-1.0.jar
Thank you,
