Java SDK Thingworx message Size too large
Hello everyone,
I am trying to update properties of a thing which is binded to a virtual thing in my Java environment. During the updateSubscribedProperties() call I get the following Error:
ERROR c.t.c.client.things.VirtualThing - Unable To Update Subscribed Properties For propName : Thingworx message size too large: 55282
Note: I am trying to set an ImagePrimitive here. The ImagePrimitive is created with a byte[] array of size 27k which is 27kilobytes in total.
I already checked the FileTransferSubsystem and the maxBlocksize is set to 128k so I don't see a problem there. Any Ideas how to resolve this? Should I use a different aproach for setting image properties maybe?
Best Regards,
Dominik
cbuseAnswer
Hi Dominik,
A different approach would be to transfer the image from a remote repository on the device in a ThingWorx repository using the Copy service from FileTransferSubsystem, then use service LoadImage from the file repository to get the image, then assign it to a property on the thing.
You would need to extend FileTransferVirtualThing instead of VirtualThing in order to use file transfer. The Java method for adding a remote repository is addVirtualDirectory("AssetRepo",  "E:/AssetRepo").
Best regards,
Cristina
cbuse13-AquamarineAnswer
Hi Dominik,
Best regards,
Cristina
drieder1-VisitorAuthor
Hello Christina,
thank you very much for your reply. I will try this out and let you know whether it worked.
Best Regards,
Dominik
