11-Garnet
Jan 29, 2024 9:07 AM UTC
JMS Connector Thingworx
Does Thingworx have any extensions to integrate JMS Connectors.
Best Regards,
Jan 30, 2024 9:12 AM UTC
ThingWorx by default does not have an extension for JMS systems.
I have created though, in the past, using the ThingWorx Extension SDK (which you should use to build such a plugin) an JMS ActiveMQ Extension.
It's really old, stored here: https://github.com/cbadici/thingworx-activemqjms-extension
Obviously, not supported by PTC (and by anyone), but the source inside is very useful if you're trying to build such an Extension.
11-Garnet
Jan 30, 2024 9:17 AM UTC
Hi Vladimir,
Thanks for sharing your build. Will check the repository.
Thanks and regards.
