3-Newcomer
Apr 20, 2026 7:27 PM UTC
JS and Drag and Drop
Hi Community,
I am a beginner in ThingWorx and trying to understand the correct way to implement custom JavaScript-based functionality in a mashup.
My requirement is drag and drop. For example, I have two columns, A and B, and I want to drag an image from column A and drop it into column B. As soon as the image is dropped, I want to call a ThingWorx service
I have a few beginner questions:
For this kind of requirement, should I create a custom widget / extension, or is there any simpler way to do it in a mashup?
If I need a custom widget, should I build it using plain JavaScript or TypeScript?
Does ThingWorx support this kind of drag-and-drop behavior out of the box, or does it need to be implemented as a custom extension/widget?
If a custom widget is the right approach, are there any beginner-friendly examples or documentation for creating ThingWorx web components/widgets? PTC’s Web Component SDK docs mention creating widget extensions and packaging web components for Mashup Builder. ()
After a drop event happens in the UI, what is the recommended way to trigger a ThingWorx service from the widget?
nmutterAnswer
Jun 2, 2026 11:51 AM UTC
You can have a look at an unofficial extension which has drag and drop: https://github.com/BogdanMihaiciuc/BMCollectionView#drag--drop (I did not try the functionality). If drag and drop is not necessarily needed you might use the inbuild collection-widget like
Implementing a custom widget for this is quite complex - would not do if another solution would be also okay.
If strings would be sufficient you may have a look at https://support.ptc.com/help/thingworx/platform/r10.1/en/#page/ThingWorx/Help/Mashup_Builder/Widgets/ListShuttleWidgetThemable.html which allows transfer from a to b (not sure via drag and drop).
Community Moderator
Jun 1, 2026 8:30 PM UTC
Hi ​@AM_12625627,
Thank you for your question.
Anurag
nmutter17-PeridotAnswer
