js code
Why window.location.hostname, window.location.host codes and showing errors inside Thing services??
PaiChungAnswer
22-Sapphire I
In your Things (Server side JScript) window and location do not exist.
if you are doing this in an Expression widget, client side, Window is not allowed.
PaiChung22-Sapphire IAnswer
22-Sapphire I
What you mean when you telling 'client side'?
22-Sapphire I
You need the code to run in a Mashup/web page on the user's machine (How you normally expect JS to be used)
