JS Code
I am reading multiple csv files one by one. If one csv file not exists error occurred, the code stopped. Instead i want to move on to reading next csv file. So i tried try catch inside for loop only for ReadCSVFile method, but that doesn't worked. What to do.
I didn't used "break" statement, still code stopping at catch. So i used "continue" statement inside catch. After error catches in catch block, code is continuing now. It is working fine now. Thanks.
22-Sapphire I
Try Catch should allow you to do what you are trying to do. You aren't breaking out of the for loop at any point on purpose are you?
AP_958723617-PeridotAuthorAnswer
