pshashipreetham
JSON in Grid Widget
When Trying to display the threshold parameter in the Grid, it is showing [object][object], How values can be displayed.
Issue with JSON Variable Display on Grid:
@c_lowy @slangley @paic
Shashi
pshashipreetham
Hi @PaiChung ,
Thanks for the quick reply, got it, should it be done from service or can it be changed in the GRID Configurations ?
followed a article here, but this didn't work.
Shashi Preetham.
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
22-Sapphire I
unfortunately the grid won't display json objects, you could convert it to string to display.
pshashipreetham
pshashipreetham19-TanzaniteAuthorAnswer
Hi @PaiChung ,
Shashi Preetham.
Support
Hi @pshashipreetham.
We tested under ThingWorx 9.2.3 and it worked fine.  Can you provide your code?
--Sharon
