Jul 30, 2019 1:43 PM UTC
Kepserverex IoT Gateway, Azure IoT Hub, ThingWorx
I'm currently sending value of simulated tag with KepserverEx IoT Gateway via MQTT message to Azure IoT Hub. I got ThingWorx Azure IoT Hub Connector working and was able to add KepserverEx IoT gateway device to ThingWorx from Azure IoT Hub.
The problem I'm having is that I cannot get Kepservers tag values visible to thing as remote property. If I try to call GetRemotePropertyMappings service I get no results. How to get original tag value visible?
Any ideas?
Thanks!
Support
Jul 31, 2019 7:11 PM UTC
Hi @randomName.
Can you provide your use case for this?  There are ways for KEPServerEX to communicate directly with ThingWorx without the need for the Azure IoT Hub.
It would also be helpful to know the versions you are running of each of these products.
--Sharon
Aug 1, 2019 8:04 AM UTC
\\Can you provide your use case for this?
Factory is already collecting data from production lines via KepserverEx Iot Gateway to Azure IoT Hub and from there to storage. I’m doing a demo at first in my own environment to get them to consider moving to ThingWorx. That’s why I thought of using same route to move manufacturing data to ThingWorx.
KepserverEx -> Azure Iot Hub -> Thingworx
Would you suggest using other kind of configuration in this situation?
\\It would also be helpful to know the versions you are running of each of these products.
I’m running KepserverEx 6.4.321.0
ThingWorx version is 8.4.0-b2013
ThingWorx Azure IoT Hub Connector is version 2.0.0.141
Regards
jhärkänen
