License error with Thingworx 8.4 on a AWS Docker
I have a Thingworx 8.4 installation running in a Docker on AWS, I tried to use my user/password to license it but it is not working. Is there any way or command to check the license server connection?
Thanks!
rjanardanAnswer
In another community post this error occurred because the account had many entitlements which was resulting in a timeout. Could you please open a support ticket?
Do you have internet access from your instance? If no, you may use the disconnected mode to install license. Refer Disconnected Mode section in this article.
If connection to license server is not working then in application log you will see an error as Unable to retrieve license from FNO server because ..
gch13-AquamarineAuthor
Yes we have internet access and the disconnected mode is not a solution for the moment because the device id will change when rebuilding the image.
What error do you see in application log?
