Nov 5, 2019 10:54 AM UTC
Licensing error on start up - Thingworx 8.2
hoping someone might have a solution to a problem we are having when applying the license bin file on startup for a linux server. It looks like it gets the license file, but fails to start up. We are running the start up as root to test.
Below is the errors we see in the application log
2019-11-04 19:48:00.571+0000 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting Subsystem [LicensingSubsystem]
2019-11-04 19:48:10.421+0000 [L: WARN] [O: o.a.h.c.p.ResponseProcessCookies] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Invalid cookie header: "Set-Cookie: visid_incap_1771292=fQXYN9JSTxC+vZ2H074m93mAwF0AAAAAQUIPAAAAAACIdU6MhoTtktTrSVr45uS5; expires=Tue, 03 Nov 2020 10:54:13 GMT; path=/; Domain=.ptc.com". Invalid 'expires' attribute: Tue, 03 Nov 2020 10:54:13 GMT
2019-11-04 19:48:18.462+0000 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Unable to process capability response because Storage anchor break found.
2019-11-04 19:48:27.906+0000 [L: WARN] [O: o.a.h.c.p.ResponseProcessCookies] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Invalid cookie header: "Set-Cookie: visid_incap_1771292=WDDZtNyURF2rT0JC8KQkB4uAwF0AAAAAQUIPAAAAAACVoETceIJfLtZ2JCGa+zxq; expires=Tue, 03 Nov 2020 10:54:13 GMT; path=/; Domain=.ptc.com". Invalid 'expires' attribute: Tue, 03 Nov 2020 10:54:13 GMT
2019-11-04 19:48:28.016+0000 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Unable to process capability response because Storage anchor break found.
2019-11-04 19:48:36.485+0000 [L: WARN] [O: o.a.h.c.p.ResponseProcessCookies] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Invalid cookie header: "Set-Cookie: visid_incap_1771292=sO3dxTVYSDKVlspU7z3+gJOAwF0AAAAAQUIPAAAAAADCjrtZrOQh5XEgqZQ8XiZs; expires=Tue, 03 Nov 2020 10:54:07 GMT; path=/; Domain=.ptc.com". Invalid 'expires' attribute: Tue, 03 Nov 2020 10:54:07 GMT
2019-11-04 19:48:36.626+0000 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Unable to process capability response because Storage anchor break found.
2019-11-04 19:48:45.931+0000 [L: WARN] [O: o.a.h.c.p.ResponseProcessCookies] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Invalid cookie header: "Set-Cookie: visid_incap_1771292=dzFLLo4hTtOWvpGxCjC2N52AwF0AAAAAQUIPAAAAAAD3bxx99B8UQD9OS2dj9Guv; expires=Tue, 03 Nov 2020 10:54:13 GMT; path=/; Domain=.ptc.com". Invalid 'expires' attribute: Tue, 03 Nov 2020 10:54:13 GMT
2019-11-04 19:48:46.045+0000 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Unable to process capability response because Storage anchor break found.
2019-11-04 19:48:46.049+0000 [L: ERROR] [O: c.t.s.s.l.LicensingStateMachine] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Unable to fetch license file with device id e2d8d1e5-b38e-45b5-a848-195207af157a
2019-11-04 19:48:46.116+0000 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Flexara threw exception when checking for previously acquired license: Storage anchor break found.
slangleyAnswer
Support
Nov 8, 2019 9:18 PM UTC
For the benefit of others on the community, this issue was the result of permissions changes.  The issue was resolved by reapplying the permissions documented in the ThingWorx installation guide (Ubuntu).
Nov 5, 2019 11:14 AM UTC
@khayes1 Per the errors in application logs, I came across these two articles, thought would be helpful for you to refer
https://www.ptc.com/en/support/article?n=CS271866
https://www.ptc.com/en/support/article?n=CS281533
Vibhuti
Nov 5, 2019 11:40 AM UTC
If you license file is named license.bin, please rename it to license_capability_response.bin. This is required for ThingWorx 8.1 and later.
khayes11-VisitorAuthor
Nov 5, 2019 12:23 PM UTC
The file is already named license_capability_response.bin. The Storage anchor break issues looks to be causing the problem - unclear what that means
Support
Nov 5, 2019 1:04 PM UTC
Hi @khayes1.
It is recommended that a case be opened for this issue.  I am happy to open one on your behalf with your confirmation.
--Sharon
