Aug 7, 2020 5:02 AM UTC
Like filter not working with special characters
When i'm filtering the things using the like filter which contains special characters, it's not returning any results. I have tried using escape characters still no result.
Did anyone face this issue? How did you overcome this?
var filterPattern = "Thingworx Navigate (TN)";
var params = {
inclusive: true /* BOOLEAN */,
fieldName: "Organization" /* STRING */,
t: Devices /* INFOTABLE */,
pattern: filterPattern + "*" /* STRING */,
var result = Resources["InfoTableFunctions"].LikeFilter(params);
-thanks,
Abhiram
CharlesJiAnswer
Support
Nov 18, 2024 3:02 AM UTC
Hi @abhiramk, in this case, you may try to use a double backslash "\\" to escape the special characters.
var filterPattern = "Thingworx Navigate \\(TN\\)";
Rocket_Max
Aug 11, 2020 3:06 AM UTC
abhiramk1-VisitorAuthor
Aug 11, 2020 11:14 AM UTC
Thanks Max for your response.
As per my understanding LikeFilter is to filter infotable rows based on columnValue matching the pattern(will provide wildcard character to filter) we provided right, my infotable is having string values only which contains special characters. It's working with string which doesn't contain spcl char's but not giving an error or response if it contains special characters.
Aug 12, 2020 7:20 AM UTC
@CarlesColl converting it to JSON and applying javascript filter and converting back to Infotable. Other than this any workarounds are possible. Can you please provide your inputs?
-thanks,
Abhiram
CharlesJiCommunity ManagerAnswer
Support
