Limit range on datetime picker widget
I have a datetimepicker widget on a mashup (TWX 8.4.1), and I'd like to limit the available range that a user can choose from. For example, my user should only be able to choose a calendar date within the past 7 days. By default, it seems that the widget has no time limits.
Anyone done this before?
posipovaAnswer
20-Turquoise
You may look into custom java widget development or modify the existing one to accomodate your needs.
posipova20-TurquoiseAnswer
20-Turquoise
ague1-VisitorAuthor
Thank you - we will start customizing then.
