Limit Things displayed based on user login when using GetImplementingThingsWithData
Greetings to All,
I'm trying to create a mashup where, using a collection, I can mini mashups of multiple things using the same template.  I was able to do this with the GetImplementingThingsWithData service for that template.
My issue is to limit what is displayed based on the user login.  And I don't just mean making it not visible, thereby creating blank spaces.  I know I can do this by creating templates and mashups for different users, but I figure there has to be a simpler way to do this without the extra work.
Thanks for your help.
posipovaAnswer
20-Turquoise
Could you try creating a custom service that checks the logic for current session/user info?
posipova20-TurquoiseAnswer
20-Turquoise
Timo69713-AquamarineAuthor
Yes.  That did it.  Thank you posipova.  I am stilling learning to make use of the API calls and services that ThingWorx provides.
I created a service to make an InfoTable using GetImplementingThingsWithData.  I then browse each row of the InfoTable to determine if the UserID value of each row matches the User Logged on.  If it does not match, I delete the row.  Below is a copy of my code if anyone is interested.
var things = ThingTemplates["Device_Template"].GetImplementingThingsWithData();
var qty = things.getLength();
for (var x=0; x < qty; x++) {
     var row = things.getRow(x);
     if (row.getValue("UserID") != ID) {
          things.RemoveRow(x);
          x = x - 1;
var result = things;
