pshashipreetham
18-Opal
December 25, 2021
Line Chart Padding Issue
  • December 25, 2021
  • 8 replies
  • 3486 views
Placed a Line Chart on the Mashup, as soon as Chart Plotted, the chart is not getting placed properly on the dashboard.
May be this is due to the Padding issue. The Line chart on the dashboard is something like this:
 How Can Padding properly set for the Line Chart.
@paic @slangley @c_lowy @VladimirN
Shashi
Best answer by pshashipreetham
The issue is solved by the CSS provided by @c_lowy .
ptcs-chart-line::part(chart-layout) {
padding: 0;
If there are 2 or more DataSources given to the Line chart,
1. Enable the Multiple Data source Visualization option in widget properties, and
2. Connect to the 2 or more Data Sources to chart widget again.
3. Select the X Axis as TimeStamp(in my case)
Shashi
Hi @pshashipreetham ,
Kindly check the below attached article:
https://www.ptc.com/en/support/article/CS343992?posno=1&q=line%20chart%20padding&source=search
Revert back in case of further challenges.
Regards
Bhawna
pshashipreetham
18-Opal
December 27, 2021
Hi @bchaudhary_448008 ,
tried the article, didn't help. The Picture in the issue posted is after trying out the article you have shared.
Shashi.
Shashi Preetham || +91 8099838801
@pshashipreetham
Have you provided values for the properties "XAxisMaxmumValues", "XAxisMinimumValues", "YAxisMaximumValues" and "YAxisMinimumValues". These properties can be bound to services if the X Axis values change based on other issues.
Hope this helps.
make the container fixed height
pshashipreetham
18-Opal
December 30, 2021
Hey Hi @GuruPrasad1 ,
Didn't get you, can you show a example ?
Shashi.
Hi Shashi,
Usually this happens when the container in which your are placing the chart is responsive, if you instead choose a fixed length and give a value say 500px this would appear better. This settings you can find in the layout tab am attching
Regards
Guruprasad S
pshashipreetham
pshashipreetham18-OpalAuthorAnswer
18-Opal
January 8, 2022
padding: 0;
Shashi
