Line chart scaling
hello,
I have a linechart where  the margins on left and right side is to big (X-axis), I would like to fill all the available space .
On the attached image I marked the space what I would like to 'cut' somehow.
Because the x axis is date type and it's variable I cannot set itXAxisMinimumValues and YAxisMinimumValues parameters.
(I using ThingWorx 9.1.5-b698)
any idea is welcome.
thank you
PEHOWEAnswer
@AK_10638440 ,
The issue you are describing can be addressed by assigning values to 2 additional properties.
  • XAxisMaximumValue
  • XAxisMinimumValue
These fields are bendable so you can create a service to provide the values if they change based on data being displayed.
A description of the fields can be found in the online documentation.
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Mashup_Builder/Widgets/LineChartWidgetThemable.html
Let me know if this address your issue.
PEHOWE17-PeridotAnswer
@AK_10638440 ,
  • XAxisMaximumValue
  • XAxisMinimumValue
